In zabbix server I see on some zabbix agents: Get value from agent failed: ZBX_TCP_READ() timed out
I checked firewall configuration - everything is allowed for both sides, checked zabbix agent configuration - everything is correct, telnet is working on both sides
and if to execute simple: zabbix_get -k agent.ping -s IP - I received: Timeout while executing operation.
Just in case transfered agent to other port, open all on firewall and received:
Get value from agent failed: cannot connect to [[80.232.254.96]:10050]: [4] Interrupted system call
Thank You,
Thank You,
