Trigger to check last 5 (Five) values of string item!!
  • paulmartinez1
    • Jul 2021
    I am experiencing some issues. I have written the problem below:
    I have set a UserParameter that sends "rsync failed" on rsync failure.
    I want to set a trigger that fires on 5 consecutive rsync failed alerts
    I tried the below Trigger cinema hd v2 expression
    {Server:rsync.status.str("rsync failed",#5)}=1 & {Server:rsync.status.str("rsync failed",#4)}=1 & {Server:rsync.status.str("rsync failed",#3)}=1 & {Server:rsync.status.str("rsync failed",#2)}=1 & {Server:rsync.status.str("rsync failed",#1)}=1
    but is not working. The trigger fires even if any one of the previous 5 values is "rsync failed".
    Can someone help me with this trigger configuration?
  • Hamardaban
    • May 2019
    • 2714
    https://www.zabbix.com/documentation...ions#footnotes
    You may use the 'count' function with the like operator to count string values that match a pattern.
    • paulmartinez1
      paulmartinez1 commented
      Thank you so much for the response.
