I'm looking for possible solution to implement log monitoring. I have a app which uses log file /var/log/webapps.log to write the errors occurred.
Application is based on Java which integrated with a Web UI through API calls. When exceptions occurs, errors will be written to the log file /var/log/webapps.log
I was able to implement the log file monitoring as per doc
Expression in the trigger used is like as shown below
{server01.intraservers.biz:log["/var/log/webapps.log","UN_EXPECTED_ERROR",,20].nodata(600)}=0
I'm able to get the alert mail when there is string ''UN_EXPECTED_ERROR" in the log file /var/log/webapps.log like as below.
Trigger: API Failure
Trigger status: PROBLEM
Trigger severity: High
Item values:
1. API Failure (server01.intraservers.biz:log["/var/log/webapps.log","UN_EXPECTED_ERROR",,20]): 2015-08-26:09:57:04,134 ERROR errorFile:141 - UN_EXPECTED_ERROR
Original event ID: 93
The problem is that, with this setup, it only print the line that is corresponding to the string "UN_EXPECTED_ERROR". I need to print next 50 lines as well after the string so that I can see the full exception occurred just like as shown below in the alert mail.
java.lang.IllegalStateException: removeAttribute: Session already invalidated at org.springframework.web.method.support.InvocableHa ndlerMethod.invokeForRequest(InvocableHandlerMetho d.java:132)
at org.springframework.web.servlet.mvc.method.annotat ion.ServletInvocableHandlerMethod.invokeAndHandle( ServletInvocableHandlerMethod.java:104)
at org.springframework.web.servlet.mvc.method.annotat ion.RequestMappingHandlerAdapter.invokeHandleMetho d(RequestMappingHandlerAdapter.java:749)
at org.springframework.web.servlet.mvc.method.annotat ion.RequestMappingHandlerAdapter.handleInternal(Re questMappingHandlerAdapter.java:690)
at org.springframework.web.servlet.mvc.method.Abstrac tHandlerMethodAdapter.handle(AbstractHandlerMethod Adapter.java:83)
at org.springframework.web.servlet.DispatcherServlet. doDispatch(DispatcherServlet.java:945)
Could someone please advise how to achieve this ?
Item values:
