Identify host
  • paulocapelett
    • Jul 2021
    Identify host
    With which item or trigger I can identify the host connected to the ethernet interface of a switch?
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    For Linux, check out the template "Linux network interfaces by Zabbix agent" which is used by Linux hosts for networking. It auto-creates stats items (like net.if.in, out etc) for every network interface available on that host and also triggers responsible for interface up/down events.
    • paulocapelett
      • Jul 2021
      Glencoe
      Ok. In the case of Windows, I have my map in SNMP, all hosts as Windows SNMP. So I wanted to know, if I can identify which host is connected to a particular port. Example: Ethernet interface g0/1/2 - "HOSTANAME" - loss. Can I know or identify this?
      • Glencoe
        Zabbix developer
        • Oct 2019
        • 153
        Zabbix reports information that is provided by your devices. If your switch can provide this information then you probably can get it into Zabbix.
        • paulocapelett
          • Jul 2021
          Glencoe
          In the trigger, the interface is pointed, ok, but I would like to show which host it is, got it?
          • Glencoe
            Zabbix developer
            • Oct 2019
            • 153
            If you mean displaying the hostname the trigger refers to, you can use {HOST.HOST} macro in the trigger name.
            • paulocapelett
              paulocapelett commented
              I'm just testing zabbix for a short time, so how would I do it? Would you have to replicate the change across all triggers?
              could you help me with an example?
              I can add some command on this line to tell me the host that is connected?
              Interface {#IFNAME}({#IFALIAS}): Bits received
          • semagn
            • Jul 2021
            Hello ,I know the the front of zabbix is written by php ,and the server is written by c,but what framework does it use of php and c,thank you!
            • Glencoe
              Zabbix developer
              • Oct 2019
              • 153
              You can just go like
              Interface {#IFNAME}({#IFALIAS}) on {HOST.HOST}: Bits received
              in the template and problems will display correct hostname. This is a bit redundant though, because problem screen shows hostnames anyway.
            • paulocapelett
              • Jul 2021
              In my interface it only brings me this...
              Interface gi1/0/20(): Bits received
              It's not identifying the ALIAS, what could it be?....and also, I'm not able to show which host is connected to it.
