ZBX 5.4.3 Graphs partly missing
  • maryjane
    • Jul 2021
    Hello everyone
    I'm running zabbix 5.4.3 and I'm having a little trouble with graphs not being shown in some places.
    As of right now most of my configured hosts are just monitored via the ICMP Ping template and that works just fine.
    My problem is that in Monitoring -> Hosts the "Graphs" field is grayed out for each of them, indicating there are no graphs available. If I click on the "Latest Data" entry for any of these hosts I'm presented with three entries (ICMP loss, ICMP ping, ICMP response time) which all have a clickable text "Graph". Clicking any of these does take me to a graph which seems to be working just fine.
    I wouldn't really mind accessing my graphs that way, however I'm also not able to create a dashboard with any of these graphs as there is "No data found" in the "Add widget" dialog when creating a dashboard.
    I've attached a few screenshots for better understanding.
    If anyone has any ideas as to why the graphs don't seem to be associated with the hosts I'd appreciate any input.
    Thank you
  • Atsushi
    • Aug 2013
    • 2028
    If the host or template does not have a graph setting, nothing will be displayed in the graph column. If you only link the template ICMP Ping to the host, there is no defined graph.
    If you want to display the graph from the graph column, add the graph definition to the host or template.
    • maryjane
      • Jul 2021
      Hello Atsushi, thank you very much That solved my problem
