Empty dashboard after update to 5.4
  • Dystopium
    • Jul 2021
    Zabbix 5.2 working fine many year. After upgrading version to Zabbix 5.4 - on Windows clients (at web-interface) dashboards are empty.
    I try all browsers and all Windows OS versions - all time same problem - DASHBOARD PAGE IS EMPTY (it doesn't matter which dashboard I use.). I cant create new dashboard (page is empty).
    What is it? And how fix it!
  • gryan337
    • Dec 2020
    What browser and version of the browser are you running? We found that Chrome version 80 and higher is required for Zabbix 5.4
    • Dystopium
      • Jul 2021
      We use Firefox 68.0.1
      • Dystopium
        • Jul 2021
        We try new browser Chrome 92 - and it working!
        • gryan337
          • Dec 2020
          That's great! It's definitely best to stay on the latest browser versions. Even Firefox 68 is pretty old.
          • Cikuzis
            • Dec 2021
            The same problem - after upgrade to 5.4 web interface is not working - tried different browsers on different computers...
Name:	Ekrānuzņēmums 2021-12-16 185846.jpg
            • vicbc
              • Nov 2021
              • 39
              Hey Cikuzis!
              Try enabling debug from the frontend to see if there's something awkward there.
              Users > Your User > Add to group "Enable Debug Mode".
              You should see a "Debug" button in the botom right of your screen.
              Then get back to the main dashboard, and click that button.
              Also, when you're navigating in the "Problems" dashboard (not this Widget in the Main Dashboard), is it alright with the problems info?
              • gofree
                • Dec 2017
                • 400
                try to clear browser cache as well - it did help in some situations
                • vicbc
                  vicbc commented
                  Yeah, that too.
                  I didn't mind telling him since he said he tried with several other browsers
              • Cikuzis
                • Dec 2021
                Originally posted by vicbc
                Hey Cikuzis!
                ok, thanks, seems that problem is only with user
                SQL (0.000223): SELECT type,value_id,value_int,value_str,idx2 FROM profiles WHERE userid=3 AND idx='web.login.attempt.failed' zabbix.php:22 → require_once() → ZBase->run() → ZBase->processRequest() → ZBase->processResponseFinal() → CView->getOutput() → include() → CWidget->show() → CWidget->toString() → get_prepared_messages() → CProfile::get() → DBselect() in include/classes/user/CProfile.php:179
                logged in with user "zabbix" and everything ir fine.
                no, "problems" windows also is empty.
                • vicbc
                  • Nov 2021
                  • 39
                  Were you able to fix the user's view in the end?
                  • Cikuzis
                    • Dec 2021
                    No, I'm using now Admin account....
                    • vinibr
                      • May 2022
                      The problem happen because the Problem dashboard is global and your filter too, if you made a filter for example in global admin, for some group hosts, this works well in your global admin account, but if you use another user and this user does not have access for group filter, the dasboard result is empty.
                      I had the same issue and after clear filter in admin account the user end logoff and login again and the works well.
                      Another thing i think is if the end user make a some filter, its apply for all? well, the Problem dashboard does not allow users for make filter, the only user level allow is super admin.
