Sporadic issue with agent communication
  • brhunt
    • Feb 2013
    • 50
    We are experiencing some odd errors between our 5.4.0 Zabbix servers and two agents on our LAN. This *seems* to have started after the latest round of MS patches, but I cannot prove a correlation.
    Here is a snippet of the agent log:
    10184:20210729:083747.976 Starting Zabbix Agent [CCNWO-HOST-02]. Zabbix 5.4.3 (revision 68dc2b05cb).
    10184:20210729:083747.977 **** Enabled features ****
    10184:20210729:083747.977 IPv6 support: YES
    10184:20210729:083747.978 TLS support: YES
    10184:20210729:083747.978 **************************
    10184:20210729:083747.979 using configuration file: C:\Program Files\Zabbix Agent\zabbix_agentd.conf
    10184:20210729:083748.864 agent #0 started [main process]
    4120:20210729:083748.865 agent #4 started[listener #3]
    5852:20210729:083748.865 agent #2 started[listener #1]
    10516:20210729:083748.866 agent #1 started [collector]
    10428:20210729:083748.866 agent #3 started[listener #2]
    10428:20210729:115727.295 failed to accept an incoming connection: from 172.16.99.235: reading first byte from connection failed: [0x0000274C] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    5852:20210729:115727.544 failed to accept an incoming connection: from 172.16.99.235: reading first byte from connection failed: [0x0000274C] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    4120:20210729:115727.576 failed to accept an incoming connection: from 172.16.99.235: reading first byte from connection failed: [0x0000274C] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    The dashboard shows these as a "Zabbix Agent is not available" alert.
    Any ideas as to what might be causing this?
    Thanks.
    Bryan Hunt
