Template systemd warnings
  • klowet
    • Jun 2019
    • 10
    Hello
    I'm using Zabbix 5.0 and I have imported the new systemd template. The problem I have is that the problems are flooded with warnings "service is not running" about services that are enabled but not started (like dmesg.service, rsync.service, netplan-ovs-cleanup.serivce, etc.).
    What is the best method to handle this?
    Kris
  • Markku
    • Sep 2018
    • 1784
    Hi, apparently the template uses macro {$SYSTEMD.NAME.SERVICE.NOT_MATCHES} that you can set in host level, use value (regex) like "^(dmesg|rsync)\.service)" to ignore specific services.
    Note that since the service discovery (LLD) is already done you may need to manually delete the items for those services.
    Markku
    • klowet
      • Jun 2019
      • 10
      Hi Markku. That is indeed a solution.
      Thanks!
      • amanogue
        • Mar 2015
        • 34
        Hi all
        I'm having the same issue as you. how were you able to solve it?
        This is the content of my macro
        ^(sssd\.service|smartd\.service|selinux-autorelabel-mark\.service|microcode\.service|nvmefc-boot-connections\.service| ostree-remount\.service|multipathd\.service)$
        . I've detached/atached the macro serveral times but warnings still apears.
        BR​
        • Markku
          • Sep 2018
          • 1784
          Did you try this:
          Markku
          • klowet
            • Jun 2019
            • 10
            I use it like this:
            Macro:
            {$SYSTEMD.NAME.SERVICE.MATCHES}
            Value:
            ^(firewalld|fail2ban)\.service
