Filtering in Trigger Expression
  • tarunwadhwa13
    • Aug 2021
    I am stuck in this issue and honestly appreciate any help !!
    Context:
    We are trying to apply trendavg function in Zabbix trigger expressions to calculate change in value. There are many userparameters (curl statements) which pull data from source, apply jq and return a numeric value
    Imp: In case source from where value is pulled is down, user parameter function returns -1
    Problem:
    Trendavg is basically consuming that -1 value as well to diluting the actual average. Average is falling, creating a lot of noise in system
    Question: Is it possible to filter values in trigger expression to only include positive values in average? Any hack to filter out values and then try to average?
    Background Information:
    Zabbix Version: 5.4
  • tarunwadhwa13
    • Aug 2021
    0 will also neutralize value. I tried discarding value but then I see a lot gaps in data. I mean, seeing the latest values for item, there are missed timestamps and it is difficult to find out whether data was discarded or there was issue zabbix polling queue.
      Preprocessing? "in range" and either discard values or replace with 0 .. for example.
