Calling wsl with UserParameter
  • dkoski
    • May 2016
    • 41
    I have created a template using UserParameter to call wsl to get the RAID status on a Windows server. The script works from CMD and PowerShell but when called from Zabbix, it fails. The log shows "cmd_result:'A'" followed by "Sending back [A]". I tested with zabbix_get on the proxy with various forms of system.run to execute wsl but the outcome is the same: zabbix_get shows a return value of "A". Is it possible to call wsl from zabbix? Even executing "wsl ls" from the PowerShell and CMD prompts works but fails using system.run.
  • dkoski
    • May 2016
    • 41
    I found that if I run Zabbix Agent as Administrator the scripts will execute but even a user in the Administrators group fails. Even the SYSTEM (default) user fails. Only Administrator will execute the scripts. So now I have to set the password for the service to track the actual password for Administrator. I see no way around that.
