Alarm if host is turned ON
  • fabiomartinsnet
    • Jul 2021
    • 15
    Hello!
    We have a server that should be turned off.
    We would like to create a kind of reverse alarm.
    So, it should be considered a problem if its turned on and alarm.
    How can we do this?
    (moderator you can delete previous topic, subject was incomplete)
  • fabiomartinsnet
    • Jul 2021
    • 15
    Originally posted by cyber
    If it is shut down it wont answer to ping. So just ping it and when it starts to answer with 1 (available), trigger something.
    Or if that host has Zabbix agent also.. agent.ping and nodata() function can help you out. If agent responds, there is data for that item. nodata(1m)=0 should indicate that there is now available agent...
    Thanks!! I did it and it´s working fine.
      Or if that host has Zabbix agent also.. agent.ping and nodata() function can help you out. If agent responds, there is data for that item. nodata(1m)=0 should indicate...
