cant find UserParameter
  • EvgenyA
    • Aug 2021
    I've just added a UserParameter to the configuration file /etc/zabbix/zabbix_agentd.conf.
    UserParameter=fping.chk,fping -e 8.8.8.8 | awk '{ print $4 }' | tr -d '('
    I've checked it with zabbix_agentd (it's fine)
    $zabbix_agentd -t fping.chk
    fping.chk [t|12.6]
    And it works if I check with zabbix_get
    $zabbix_get -s 127.0.0.1 -p 10050 -k "fping.chk"
    12.9
    I restarted both server and agent, but still can't see fping.chk in the list of keys in the new data item page.
    Do you have any idea of what went wrong?
    Thanks in advance!
  • Atsushi
    • Aug 2013
    • 2028
    Add it as an item to the host or template.
      UserParameters do not show up inthe list like built in ones. You just need to know them and use them, where appropriate..
