Hi All,
I have the following template which I made myself
and then a script which I found on this forum
Script and items work great but problems trigger when they should not.
For example the certificate expires in 394 days but the trigger for 7 days goes off.
I believe this is due to the expression, anyone know what I am doing?
Example of an expression I'm using which should not be triggering
HTML Code:
#!/bin/bash
#Prepared by Marcin 'szremo' Szremski'
SSL_DATE=$(echo | openssl s_client -servername $1 -connect $1:443 2>/dev/null | openssl x509 -noout -dates | grep notAfter | awk -F = '{ print $2 }' | awk 'BEGIN {OFS = "-"} {print $1,$2,$4}')
EXPTIME=$(date -d$SSL_DATE +%s)
TODAY=$(date +"%b-%d-%Y")
CURRENT=$(date -d$TODAY +%s)
NUM=$(($EXPTIME - $CURRENT))
RESULT=$(($NUM/86400))
echo $RESULT
HTML Code:
nodata(/Template MADE SSL Monitoring/ssl_valid.sh[{$HOSTNAME1}],1d)<={$THRESHOLD3}
