PowerBI and Zabbix Integration
  • simonma
    • Aug 2021
    I'm trying to integrate my Zabbix instance with Power BI.
    I've been following the following document - https://www.spikefishsolutions.com/p...ktop-to-zabbix. This document references an http instance.
    My Zabbix instance is using SSL with a self-signed certificate and I can't connect to it from latest version of PowerBI Desktop.
    Error message "DataSource.Error: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel."
    The certificate is valid.
    I've tried installing the certificate in to local Trusted Root Certificate Authority but it is still unable to connect.
    Is anyone able to assist?
    Regards,
    Simon
