Formular in Item
  • newan
    • Sep 2015
    Formular in Item
    within my application, I receive a value for the temperature that needs to be converted to a celsius value (using a specific formular such as 0.01 * value etc.).
    The value is stored in an item.
    At the momment I need to create a second (virtual) item to apply this conversion.
    Is it possible to create an item that includes this formular to make the creation of a second item obsolete?
    sincerely
    newan
  • teskistajer
    • Sep 2015
    • 19
    i am newbie too,i dont know creating a new value but you can do calculation and apply new value to the old one ? , check documents;
    edit : oh i found that you can create item with calculated type so you can use this to create new variable i think ,check it out that too
    • newan
      • Sep 2015
      Thanky, for your feedback.
      In my fist post i wrote that my solution is to create two item(one of this as calculated - virtuell), but i search for a solution with one item
