Hashicorp Vault token period
  • linuxmkd-hox
    • Aug 2021
    Hi Im wondering if anyone manage or if there is any solution about the the 32 Max ttl of a token. Im really anoyed that I have to change the token every 32 days. Am i missing something ?
  • aram535
    • Aug 2021
    Use the vault agent, and an approle (or any other auth method). The agent can setup to auto re-auth every so often so a token is always available. Now your application can talk to the agent rather the vault instance directly and no token is needed.
