Create an item for total cpu % usage on VMWare Guest Template
  • FabrizioA
    • Sep 2015
    • 33
    In my VMWare Guest Template, I need to create an item to calculate the "total vm cpu usage percentage" of VM side view.
    I've tried with VMWare perfcounter (Simple check item type):
    vmware.vm.perfcounter[{$URL},{HOST.HOST},"cpu/usage[average]"]
    but I get a value greater then 100%....
    How can I get one percentage value of VM CPU usage calculated from Total CPU (mhz?) Host's capacity?
    I'm using Zabbix 2.2.10.
    Thanks in advance!
    F.
  • teskistajer
    • Sep 2015
    • 19
    i dont know vmware but maybe you typed wrong order on calculation
    cpu/usage[average] maybe true one is usage[average]/cpu ?
    • mobarrio
      • Aug 2017
      • 18
      I Use Use custom multiplier 0.01
      • zaheerabbas1988
        • Feb 2020
        • 22
        Thanks in advance!
        F.
        Did you find the solution for this?
