Action condition application not like
  • LenR
    • Sep 2009
    • 1011
    We have setup several items with applications like "Admin" to indicate items to notify the sysadmin teams. But some things could be both admin and application issues, in that case, the item has multiple applications.
    What will happen on an action condition of "application not like admin"? Will it match if there are applications that are not like "Admin" or not match because ONE application matches?
    For example c:\ space could be either admin or app owner, but some service not running could be admin only.
  • gleepwurp
    • Mar 2014
    • 119
    Hi LenR,
    I expect that since the trigger is linked to an item which belongs to one of the application that contains the string "not to match", it would not generate an action.
    Best way to make sure would be to test it, should not be hard to do.
    G.
