Good Morning I have a question about how to do some preprocessing of a XML XPATH.
I am setting up monitoring of a MySQL database I am using a mysql query "show global status" to get the XML XPATH file. From this i build a handful of dependent item that i run the preprocessing. These keep erroring out.
The XML XPATH file looks like this:
For the first item i want the Aborted Clients so i have setup a preprocessing like this:
XML XPATH /resultset/row[field/text()='Aborted_clients']/field[@name='Value']/text()
The type of information I have now is text, but i really want a number.
Attached is a word doc with screen shots.
OH, i am running the Zabbix 4.4 server and agents on a Oracle Linux 7.8 servers.
| 2021-08-12 09:06:59 | mysql: [Warning] Using a password on the command line interface can be insecure. <?xml version="1.0"?> <resultset statement="show global status " xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <row> <field name="Variable_name">Aborted_clients</field> <field name="Value">755</field> </row> <row> <field name="Variable_name">Aborted_connects</field> <field name="Value">930</field> </row> <row> <field name="Variable_name">Acl_cache_items_count</field> <field name="Value">0</field> </row> <row> <field name="Variable_name">Binlog_cache_disk_use</field> <field name="Value">0</field> </row> |
