LDAP Authentication Integration
  • fabiomartinsnet
    • Jul 2021
    • 15
    Hi! I am new to Zabbix.
    We did configuration for LDAP authentication.
    As I understood, to LDAP authentication work, zabbix username must match active directory username. OK, It´s working fine.
    Is that possible to config authentication based on active directory group?
    For example:
    - create an AD group like "Zabbix Admins" and all users that are member of this AD group could access Zabbix Console as Admin.
    - create an AD group "Zabbix Users" and all users belonging tho this AD group could access Zabbix console as a simple user.
    It could avoid have to create user in more than one place... Just create in AD, put in a group and than it has Zabbix Access.
    If it´s possible, any step-by-step to do this?
    Thanks in advance.
    FM
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    That's what's been asked here: https://support.zabbix.com/browse/ZBXNEXT-276
    You are welcome to follow and vote for it.
    • fabiomartinsnet
      • Jul 2021
      • 15
      Voted, thanks!
        Nope...
        Only if you make somekind of sync script which creates users and assigns permissions over API.
