Use only custom intervals for item check
  • Valinor
    • Sep 2020
    • 20
    I have an item that only needs to be checked on 4,9,14,19, etc. minutes, but I can get rid of checks from the Update interval field, even if they run once per day, sometimes it gets me false positive alerts. Is there any way to set the Update interval to one year for example or make it use only a custom schedule?
  • gofree
    • Dec 2017
    • 400
    set update interval to 0
    • Valinor
      • Sep 2020
      • 20
      That easy, sorry for bothering you! Thank you, guys!
        And besides that, item has to be passive!
        Custom intervals You can create custom rules for checking the item:
        Flexible - create an exception to the Update interval (interval with different frequency)
        Scheduling - create a custom polling schedule.
        For detailed information see Custom intervals.
        Time suffixes are supported in the Interval field, e.g. 30s, 1m, 2h, 1d.
        User macros are supported.
        A single macro has to fill the whole field. Multiple macros in a field or macros mixed with text are not supported.
        Scheduling is supported since Zabbix 3.0.0.
        Note: Not available for Zabbix agent active items.
