Unable to access Web UI..
  • tryllz
    • Jun 2021
    • 29
    I configured zabbix Web UI now its not accessible, I can ping the zabbix IP address but the web UI doe not open, I have tried on more than 1 browser. Neither does it Time Out nor does it show any error.
    Any help would be appreciated.
  • tim.mooney
    • Dec 2012
    • 1432
    You need to provide some additional information about your environment for someone to be able to help you determine what the problem is.
    There are may different ways you can install the Zabbix frontend (web interface), including from source, via official packages, via unofficial packages, via a container, etc. Which way did you use to install the front end?
    What operating system and version (or Linux distro version) is on the server that's hosting the front end?
    What version of the Zabbix frontend did you install?
    Have you looked at your web server's log files, to see if there are any obvious errors in the log files?
    Have you looked at your PHP logs for any errors?
    • tryllz
      • Jun 2021
      • 29
      Sorry the issue is resolved, it was a browser cache issue, reset the browser, cleared cache, history etc, rebooted the machine.
      The whole zabbix was installed manually.
      • tryllz
        • Jun 2021
        • 29
        Sorry,
        This seems to be some other issue, just yesterday it started working, now again the Web UI cannot be accessed.
        I performed a fresh install (appliance), I was only able to access the Web UI the 1st time when I configured the IP. Once I set the SNMP traps, download the snmp tools, configure, reboot the zabbix server, thats it, the Web UI no longer loads.
