Alias hostname to Zabbix agent active.
  • ricardobarbosams
    • Aug 2021
    Hi all.
    Is it possible to create a hostname alias in Zabbix frontend? I ask because I monitor 2 mysql servers (primary/secondary), the hostnames are db01 and db02 but I have an alias for the primary called dbprimary, using this alias when we need to make the change in case of a problem in the primary mysql, thus doing the secondary would be the new dbprimary and I have some items of type zabbix agent active, but the active items need the hostname parameter name to match the frontend name. if you could leave the alias floating between the 2 hosts (db01/db02)
    Att.
