Triggers to VCenter
  • sphtd7
    • Dec 2020
    • 52
    Triggers to VCenter
    Hi, I added VCenter to Zabbix using "Template VM VMware", machines have been detected, added from "Template VM VMware Guest". Now the question is, do I have to manually create each trigger for each detected machine and for Datastore, cluster, etc.?
    Unless you have a "package" ..
  • sphtd7
    • Dec 2020
    • 52
    Originally posted by cyber
    If your guest and hypervisors have been found (by discoveries in "Template VM VMware"), they already should have either "Template VM VMware Guest" or "Template VM VMware Hypervisor" attached.
    Datastore and cluster discoveries are also done by "Template VM VMware" template.
    There seems to be a 1h interval for all those discos, so wait 1 hour... or push "check now" ...
    Templates have been added by discovery, but they only have items, not triggers
    • sphtd7
      • Dec 2020
      • 52
      I thought so, I will add in my free time and learn by the way because I can't yet .. Maybe there will also be someone who already has it
          Whoops, I completely overlooked that.. There's really no triggers in templates.I am not using those myself..
          So yea. if you need triggers then you shoudl create those by yourself.. but not to each host one by one, but in template already, so they will be added during discovery.
