How to monitor a HTTP/0.9 server
  • levon74
    • Aug 2021
    Hi all,
    Happy to join the community.
    I have a piece of hardware equipment that provides an embedded HTTP telemetry that I need to monitor with Zabbix.
    I have Zabbix server version 5.2.6 and it seems that the equipment's embedded web server supports only HTTP/0.9 since this is what Zabbix currently returns:
    2021-08-20 12:36:37 Unsupported protocol: Received HTTP/0.9 when not allowed
    When I'm trying to get the telemetry with curl I'm getting the same error message:
    # curl http://10.2.8.10/monitor/temperature/temperature1
    curl: (1) Received HTTP/0.9 when not allowed
    If I add --http0.9 to the curl command I'm getting a proper reply:
    # curl http://10.2.8.10/monitor/temperature/temperature1 --http0.9
    {"temperature1": 34.69}
    This is how the item is configured:
    type: HTTP_AGENT
    key: temp_1
    applications:
    timeout: 10s
    url: 'http://{HOST.IP}/monitoring/temperature/temperature1'
    I tried using Web Scenarios as well, setting different client browsers but have all the same result.
    Does anyone know how to make Zabbix accepting HTTP/0.9 responses if it's possible at all?
    If the HTTP Agent item uses curl under the hood, is it possible to set --http0.9 somewhere manually to get Zabbix to understand v0.9 replies?
    Thank you,
    Levon
  • Hamardaban
    • May 2019
    • 2714
    Try compiling curl with http2 support.
    may be it's wrong warning about unsupported protocol...
    • levon74
      • Aug 2021
      Hi Hamardaban,
      Thanks for your response, I ended up using just an external check with a curl command and a couple of postprocessing steps.
      Not the most elegant solution, but enough for now.
      Cheers,
      Levon
