Host availability based on SNMP traps.
  • ctux
    • Aug 2021
    Hi all,
    I need to monitor a host that has very severe hardening. The only way to monitor it is to collect SNMP traps.
    Every 15 minutes the host sends a trap to say it is still alive... How can I configure the host availability based on this passive process?
    Zabbix version: 5.4.3
    Thanks in advance!
  • Hamardaban
    • May 2019
    • 2714
    You can use the "nodata" function and fire the trigger when there is no trap data for more than 15 minutes.
    • ctux
      • Aug 2021
      Thank you for your valuable suggestion, it works!
      I would love to be able to associate host availability with this trigger.
      Is this possible? Or does it only work with active checks?
      Thank you
      • ctux
        • Aug 2021
        Ok, thanks
