How to monitor Secure POP and IMAP?
  • overrider
    • Oct 2006
    • 36
    Hello all,
    how can i modify / customize an Item to monitor wheter my POP and IMAP service are up? They are not on 143 and 110, but rather on 993 and 995.
    Thanks a lot,
  • knarfling
    • Sep 2006
    • 47
    different ports
    Net.tcp.service will monitor any port for any service that you wish. For example you can modify the keys in the items to be
    net.tcp.service[pop,,993]
    net.tcp.service[imap,,995]
    I customize our ssh port and monitor it this way.
    • overrider
      • Oct 2006
      • 36
      doesnt want to wortk for me
      hi, thanks for your reply, for some reason this will not work for me. the item just shows a 0 as if "not running".
      • overrider
        • Oct 2006
        • 36
        yeah really not; net.tcp.service[imap,,993] this will yield a 0 for not running. but if i telnet host 993 it does connect, as obviously there is something running on that port. can anyone give a tip why this isnt showing? net.tcp.service[smtp,,25] for example works fine.
        • amlt
          • Feb 2007
          Hello!
          I have same problem:
          I want to monitor pop3s and imaps services.
          I creating a trigger with this expression: {mail.copmany.com:net.tcp.service[pop,,995].last(0)}=0
          and getting error message "No such host (mail.copmany.com) or monitored parameter (net.tcp.service[pop,,995])".
          That I doing wrong? Zabbix ver. 1.1.5
          upd, problem fixed
          • clubbing80s
            • Sep 2005
            • 109
            even the defaut net.tcp.service[*] don't work for me .. ?
            any ideas why this would be ?
