No data in grafana
  • sphtd7
    • Dec 2020
    • 52
    No data in grafana
    Hi, I'm monitoring the SMART drive of one Win7 computer. Zabbix data collects correctly, while Grafana has "no Data" in some fields. Other devices show up well, it worked even before the weekend .. After restarting the grafans, such a thing happened. Click image for larger version
ID:	430321 Click image for larger version
ID:	430322 Click image for larger version
ID:	430317 Click image for larger version
ID:	430318 Click image for larger version
  • Noobz
    • Jun 2020
    • 105
    I regularly have to log out of Grafana and log back in due to errors like this, especially after making any changes to the dashboard.
    • sphtd7
      • Dec 2020
      • 52
      I did so. First, I removed the computer from the tempales / operating system group, I added a new PC group in zabbix. I didn't see this group in grafana so I added PCta again to TemplatesOperating systems group. And what? And it started to work ...... And by the way, I did a plugin update (I just pressed the udpate button, with cli I also pasted the update command, but it still shows that there is an xD update) then I restarted and it works ....... .....
