Zabbix Agent2 Linux for ppc64 Systems
  • cflannigan
    • Aug 2021
    • 9
    Hey.
    I have looked around the zabbix repo and on the main site but i cannot find a pre-compiled zabbix agent2 for linux running on power. Does anyone know if one exists or am i going to have to compile my own and build an RPM for it?? i did do a scan through the forum and couldnt find anything about it either..
    Colum
  • tim.mooney
    • Dec 2012
    • 1437
    Colum-
    I'm pretty sure it doesn't exist in pre-packaged format. If you end up building your own package, you might want to take a quick look through the Zabbix bugtracker (support.zabbix.com) to see if anyone had to do the same thing in the past. They may have submitted (open or currently closed) tickets with any changes they had to make to the spec file to get things to work on that architecture.
    Good luck!
    Tim
    • cflannigan
      • Aug 2021
      • 9
      Thanks Tim, ill check the bugtracker just in case otherwise ill get a dev system built where i can compile and build a custom rpm.
