Custom Script on Zabbix
  • Arethusa
    • Aug 2021
    I'm new on Zabbix and I want to increase my skills on it ^^
    I usually use Check_mk, and I create custom bash script like that :
    #!/bin/bash
    # /usr/lib/check_mk_agent/local/
    varstatus=$(systemctl status filebeat | grep Active | sed 's/.*(\(.*\)).*/\1/')
    if [ "$varstatus" = running ]
    then
    status="0"
    statustxt="Service is running"
    else
    status="2"
    statustxt="check service status !"
    fi
    echo "$status Check_service_Filebeat - active ($varstatus) -> $statustxt"
    I try to read documentation but I am not sure to understand how I can create custom script like this.
    Thank you.
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 152
    Even though Zabbix can be used as a script launcher on steroids, there is a support for many popular applications, devices and OSes out of the box.
    In your case, you can use systemd.* items in Agent2: https://www.zabbix.com/documentation.../zabbix_agent2
    • Noobz
      • Jun 2020
      • 105
      I think you're looking for "actions" - so you create your items, then create triggers which refer to those item values, then your trigger action would be to run a script.
