Determine if SNMP host is down?
  • dstubbs
    • Oct 2006
    • 11
    How can I determine if a SNMP host is down?
    I am monitoring a managed switch(TigerSwitch 6924M) which of course does not use the agent; strictly SNMP.
    I am monitoring 3 stats on it currently.
    sysName (system.hostname)
    ifInOctets1 (net.inpackets)
    ifOutOctets1 (net.outpackets)
    I have tried this trigger but it is falsely triggering.
    {Switch:net.inpackets.nodata(60)}=1
  • peter_field
    • Jun 2006
    • 71
    Maybe simple checks?
    You could try putting a simple check (icmpping) onto it as well, and trigger off that.
    • baalrukh
      • Aug 2006
      Not the best way, but i'm using the sysName, if it as no return in 70 sec, it marks it down, the trigger is set in 60 sec, to avoid getting missreads
      • den_crane
        • Feb 2006
        • 272
        What Item (Update interval (in sec)) you use? May be nodata(60) is too short?
        Check log for errors:
        cat /zabbix_server.log |grep vol
        015913:20061009:120124 Host [san-vol-2]: first network error, wait for 15 seconds
        015911:20061009:120143 Host [san-vol-2]: another network error, wait for 15 seconds
        015911:20061009:120159 Host [san-vol-2]: another network error, wait for 15 seconds
        015911:20061009:120215 Host [san-vol-2] will be checked after 60 seconds
        I use next triggers expressions:
        {cisco_t:sysUpTimeInstance.nodata(300)}=1
        {cisco_t:IF-MIB::ifOperStatus.3.last(0)}#1
        Work's fine.
        • dstubbs
          • Oct 2006
          • 11
          Problem solved
          This solution worked great.
          Thanks all for the advice!
