Zabbix Java Scripting
  • Sunrise0318
    • Feb 2017
    • 24
    Hello.
    I create one script item and write a javascript program but not work in frontend.
    var request = new CurlHttpRequest();
    var data =(request.Get("data"));
    for (var i =0; i < 5;i++){
    return i;
    Zabbix.Log(3,i);
    If write return i write only one number. This 0.
    How to write all data from for loop?
    Than you for help me.
  • Sunrise0318
    • Feb 2017
    • 24
    Hello.
    I have a read data from http rest api.
    My response string is:
    {"chassis":
    [{"name": "000",
    "faulted": false,
    "manufacturer": "xxxxxx",
    "model": "xxxxxx",
    "part": "xxxxx",
    "serial": "xxxxxx",
    "type": "system",
    "rpm": "--",
    "locate": false,
    "href": "chassis-000"
    {"name": "001,
    "faulted": false,
    "model": "xxxxxx",
    "part": "xxxxx",
    "serial": "xxxxxx",
    "type": "system",
    "rpm": "--",
    "locate": false,
    "href": "chassis-001"
    I would like create discovery item.
    Ok so I create javascript and add data filed for json:
    {"data":[{"chassis":
    [{"name": "000",
    "faulted": false,
    "model": "xxxxxx",
    "part": "xxxxx",
    "serial": "xxxxxx",
    "type": "system",
    "rpm": "--",
    "locate": false,
    {"name": "001,
    "faulted": false,
    "model": "xxxxxx",
    "part": "xxxxx",
    "serial": "xxxxxx",
    "type": "system",
    "rpm": "--",
    "locate": false,
    So i create discovery item but LLD macro not work.
    I have test lld macroing this sting:
    $.chassis..name
    But my error:
    Cannot create item unsupported construct with string ["\000"\,"\001"]...
    Please help for me.
    Thank you
