Multiple values for regular expression preprocessing
  • markfree
    • Apr 2019
    • 875
    Hey guys.
    I'm trying to filter some data from a text item.
    The item collects something like this:
    users[0].Name=default
    users[1].Name=admin
    I wish to get just the user's name, so, I tried to preprocess it with this regular expression:
    Pattern = Name=(\w+)  Output = \1
    And it works, but just for the first occurrence. Other occurrences are ignored.
    Then I tried to add some flags
    /Name=(\w+)/gm
    But that gives me an error
    cannot perform regular expression "/Name=(\w+)/gm" match for value of type "string": pattern does not match
    I'm not sure how to get multiple values that match that expression.
    Any ideas?
  • Semiadmin
    • Oct 2014
    • 1626
    1. CSV to JSON, delimeter =, without header row
    2. JSONPath: $..['2']
    • markfree
      • Apr 2019
      • 875
      That works and I can capture values after "=" delimiter.
      But, see... My dataset comes with more then just username data. So I have something like this:
      users[0].Id=3
      users[0].Group=user
      users[1].Id=338
      users[1].Name=admin
      users[1].Group=admin
      By using "JSONPath" step, it gives me a list with other data that are not interesting to me right now.
      ["3","default","user",(...),"341","admin","admin",( ...)]
      I'm only looking for "Name" strings.
      I also tried trimming left string like "users[0]." but it only trims the first line.
      • Noobz
        • Jun 2020
        • 105
        Are you looking to get a single users name as a returned value or an array of all users names contained within the string?
        It looks like JSONPATH (Just add ".Name" to the above) could be used here as mentioned above, or use javascript preprocessing to do this with regex, I've had to make many items this way.
        • markfree
          • Apr 2019
          • 875
          By converting CSV to JSON with no header, column names are generated automatically. The dataset is converted like this.
              "1":"users[0].Id",
              "2":"3"
              "1":"users[0].Name",
              "2":"default"
              "1":"users[1].Id",
              "2":"339"
              "1":"users[1].Name",
              "2":"admin"
          So, "Name" data actually becomes a value for column 1.
          I'm not a big fan of Javascript but, if there's no other option, that might get the job done.
          • Noobz
            • Jun 2020
            • 105
            If you have an actual data set, I can take a look for you. I've just gone through a bunch of this myself. JS is always my last resort, but I've had to use it several times.
            • markfree
              • Apr 2019
              • 875
              It is basically like this
              users[0].Id=3
              users[0].Group=user
              users[0].ClientType=GUI
              users[0].ClientAddress=Local
              users[0].LoginTime=28/08/2021 03:01:00
              users[1].Id=338
              users[1].Name=admin
              users[1].ClientType=CGI
              users[1].ClientAddress=xxx.xxx.xxx.xxx
              users[1].LoginTime=03/09/2021 17:36:56
              There might be more users (users[n])
              • Noobz
                • Jun 2020
                • 105
                And what is the result you want? An array of all users? A particular user? An item prototype creating an item for each user?
                • markfree
                  • Apr 2019
                  • 875
                  This is not really a necessity of mine, but a request.
                  I'm chatting with users to better understand their needs.
                  I'll collect Name, Group, ClientType, ClientAddress and LoginTime.
                  At first, I thought of presenting these values with Data Overview widget. That's not definitive, though.
                  These data will probrably go to Grafana.
                  • Semiadmin
                    • Oct 2014
                    • 1626
                    Step 2:
                    JSONPath: $.[?(@.['1'] =~ "Name")].['2']
                    • markfree
                      • Apr 2019
                      • 875
                      Originally posted by Semiadmin
                      Step 2:
                      This works.
                      Now, I can collect multiple "names" ou something else.
                      Data is shown as an array of strings, which is not ideal yet.
                      ["user","admin"]
                      Anyway, that's an advancement.
                      Thank you.
