Monitor multiple istances of MSSQL on the same server using the MSSQL by ODBC
  • dynux
    • Aug 2020
    • 12
    i am monitoring a MS SQL Server with two instances.
    Using the template "Template DB MSSQL by ODBC" i have the possibility to monitor only one istance.
    I tried to clone the host but Zabbix is not permitting to have two hosts on the same agent.
    How i can manage to monitor two istances of the MS SQL on the same server?
    Zabbix: 5.0.14 LTS
    Thank you very much.
  • dynux
    • Aug 2020
    • 12
    Originally posted by cyber
    Zabbix allows nicely to have 2 or more hosts, that point to same agent... You just have to name them differently. Hosts name is unique, so name your hosts based on DB names for example. You can still point them to same agent. You just cannot use active items in such case.
    Thank you very much!!
