I' ve installed Zabbix 5.4 on ubuntu, everything is fine so far, i just need some help.
Although i disabled some items that i do not need on my monitored devices, after some time ( maybe an hour ) i find them enabled again...
The same happens if i delete them, after some time i can see them again...
So, how can i permanently disable or delete items that i do not need to monitor ?
Or maybe, how can i exclude the dynamic interfaces from being discovered ?
Thanks...
Edit: Solved it using Regular expressions ...
Thanks...
