Monitoring cisco 3750 stack template needed! :(
  • Kira
    • Sep 2015
    Hiya! I 've installed zabbix 2.4
    I m trying to find cisco 3750 template.. but I didn't find it same within template for cisco 3750 stack (3-4 switches in stack)..
    Any help are very appreciated!!!
    Help pleazzze!
  • Hernandes Martins
    • Apr 2011
    • 901
    Then,
    I suggest create you template specifc, use LLD or initial template snmp devices.
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Kira
      • Sep 2015
      So what template I should to use? Oo
      • Hernandes Martins
        • Apr 2011
        • 901
        kira,
        Create a new template.
        Configuration>>Templates>>Create Template
        in new template create aplication, itens, triggers, graphs, screens, discoverys ...
        look MIB for cisco and search model specific.
        http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectIn put=1.3.6.1.4.1.9.9.13.1.3.1.3
        __
        Att.
        Skype: hernandss
        Español
        Português
        • Linwood
          • Dec 2013
          • 398
          You can also hunt around for sample templates. Here's a spot to check:
          The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
          and
          Join the friendly and open Zabbix community on our forums and social media platforms.
          The problem is these are a mixture of good and bad, and not much vetting of what is posted. And to be fair, one person's idea of what to monitor is another person's waste of time.
          I started with some of these, then finally took several and laid out on a spreadhseet what they were monitoring and compared and picked what I liked from each and made up my own.
          I think the... occasional? frequent? .. practice of zabbix users of just monitoring everything in the mib they can discover is sometimes misplaced, especially in a large environment where this can lead to hundreds of thousands of items. Personally I think you ask "When is the last time I needed to know that" and if the answer is lost in the depths of time, don't monitor it. You can always add it later. I think this all-items approach is also exacerbated by some tools you can also search for that automatically turn a MIB into a template.
