Hi.
I am trying to add a trigger to alert if the memory percentage is used is greater than 80% and I can't quite figure it out.
Using Zabbix 5.0 and this is for a Windows Server OS.
I am wanting it to alert if the memory percentage is over 80% for 30 mins and so far my codes are not being accepted.
Does anyone have any insight?
I had started with this as I found it but it is not accepting the syntax. - vm.memory.size[pused].avg(30m)}>80
Thanks.
Thanks.
