monitoring autofs mount points
  • webdev.gk
    • Apr 2018
    Hi gurus, I am looking for solution on how to monitor autofs mounts. The mounts are not visible via vfs.discovery but if you do an ls, autofs will automount.
    I am trying to use userparameter and vfs.fs.mounted[/some/folder/here”rw”]) but the latest data doesn't seems to update the value unless the agent is restarted not sure why.
    appreciate your advice and inputs thanks.
