Windows agent problem
  • swtch3k
    • Sep 2015
    hi,
    i cant get connection from the zabbix server to a windows agent.
    had read other topics and the manual without succeed.
    my enviroment=
    - zabbix server (rasbberry pi) with hostname rasp-zabbix
    - an agent on the zabbix server, which is gatherd with succeed
    - a second agent on a windows client with no succeed
    (Get value from agent failed:*** cannot connect to ip-adress:10050 :[4] interrupted system call
    my configuration on the windows client x64:
    zabbix folder with the agend and the config file with:
    server : zabbix-server-ip-adress (not 127.0... because it works with a proxy)
    Hostname:examle01.at.no.intern
    ServiceActive: zabbix-server-ip-adress
    installed with zabbix_agentd.exe --config zabbix_agentd.conf -install
    and started the agent with zabbix_agentd.exe --config zabbix_agentd.conf -start
    then open port 10050 on this client
    on zabbix i selected configuration->Hosts->create host->
    Group : windows client
    IP adress : ip-windows-client
    connect to ip adress
    zabbix agent port 10050
    monitored by no proxy
    linked with windows template -> and i get that red "Z"
    Issue on dashboard : Server is unreachable
    i disabled the proxy on the zabbix-server -> no succeed
    the proxy on the client is enabled.
    ping from server to client -> succeed
    agent_log on windows client with no error
