Hi
My Ubuntu version 21.04
i can not install from source package
i can not install from deb package too
when i work to setup it , i took an zabbix log
No create.sql.gz
So , i imported schema.sql.gz.And than i took an error
cannot use database "zabbix": its "users" table is empty
I have no hope anymore for ubuntu 21.04
can you help me please ?
Thank you very much
HTML Code:
153020:20210912:223041.977 Web monitoring: YES 153020:20210912:223041.977 VMware monitoring: YES 153020:20210912:223041.977 SMTP authentication: YES 153020:20210912:223041.977 ODBC: YES 153020:20210912:223041.977 SSH support: YES 153020:20210912:223041.977 IPv6 support: YES 153020:20210912:223041.977 TLS support: YES 153020:20210912:223041.977 ****************************** 153020:20210912:223041.977 using configuration file: /etc/zabbix/zabbix_server.conf 153020:20210912:223041.981 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
HTML Code:
root@--------:/usr/share/zabbix-server-mysql# ls -l total 1668 -rw-r--r-- 1 root root 562338 Şub 1 2021 data.sql.gz -rw-r--r-- 1 root root 127 Şub 1 2021 double.sql.gz -rw-r--r-- 1 root root 1093235 Şub 1 2021 images.sql.gz -rw-r--r-- 1 root root 14524 Şub 1 2021 schema.sql.gz -rw-r--r-- 1 root root 48 Nis 28 2018 zabbix -rw-r--r-- 1 root root 21400 Şub 1 2021 zabbix_server.conf
No create.sql.gz
HTML Code:
root@---:/usr/share/zabbix-server-mysql# locate create.sql.gz root@---:/usr/share/zabbix-server-mysql#
Thank you very much
