SNMP data delayed (not coming properly)- disconnected graphs
  • zabbixfk
    • Jun 2013
    • 256
    I am trying to monitor and collect data from some switches/routers/firewalls, using snmp v2.
    What i observe is most of the time, data isn't hitting zabbix or its delayed.
    Not sure what is causing this.
    My current NPVS is 93, it is monitored via zabbix_proxy instance. and i see proxy holding more than 350+ items more than 10 mins.
    The loss of data resulted in graphs with dots rather than straight line.
    Is this something to do with proxy settings? I don't see any settings other than
    StartSNMPTrapper=1
    My proxy config file looks like this,
    Server=zabbixmaster.internal.com
    Hostname=zbx-proxy1
    LogFile=/var/log/zabbix/zabbix_proxy.log
    LogFileSize=150
    DebugLevel=4
    PidFile=/var/run/zabbix/zabbix_proxy.pid
    DBName=zabbix
    DBUser=zabbix
    DBPassword=zabbix
    ProxyLocalBuffer=1
    ProxyOfflineBuffer=2
    ConfigFrequency=300
    DataSenderFrequency=10
    StartPollers=70
    StartPollersUnreachable=15
    StartTrappers=30
    StartPingers=60
    StartSNMPTrapper=1
    ListenIP=192.168.0.2
    CacheSize=1G
    StartDBSyncers=25
    HistoryCacheSize=1G
    HistoryTextCacheSize=256M
    Timeout=30
    UnreachablePeriod=70
    FpingLocation=/usr/sbin/fping
    LogSlowQueries=300000
    Below is the example. Here i am trying to get traffic details of an interface of a router. I am pulling every 6 mins (360sec) - but i see only limited entries instead of 10 for an hour.
    Can anybody share how snmp data pull works ( i am doing snmp_get i guess) - as i have not able to get snmp_traps working
    Can anybody share how snmp stuff works on zabbix.
    Also please suggest if i need to tweak some settings.
    PS: I am running zabbix with 2.0.6 version, and proxy server is also of same version.
  • zabbixfk
    • Jun 2013
    • 256
    Hi
    Can anybody share the idea/feedback/suggestion. The disconnection in graphs is increasing for SNMP based traffic monitoring, and i am stuck with no data
    • zabbixfk
      • Jun 2013
      • 256
      Any pointers?
      • ingus.vilnis
        • Mar 2014
        • 908
        First thing I see that your proxy configuration is far from optimal for your NVPS.
        Please adjust the settings as many other performance tuning articles suggest. You can start with this for example.
        Check Zabbix server and proxy logs to find any errors related to SNMP hosts you are monitoring.
        Best Regards,
        Ingus
        • zabbixfk
          • Jun 2013
          • 256
          Disconnected graphs for SNMP related monitoring items ( traffic )
          This is happening again. I am not sure what exactly should i be checking on the logs. SNMPget/walk gives me actual data and it works fine. Where as i see lot of disconnected graphs on zbx. What is the parameter requried to be adjusted for snmp poll in zabbix_proxy.conf - does increasing this lonely help?
