Zabbix LTS 5.0 vs Zabbix 5.0
  • dsunil79
    • Sep 2021
    Hi All
    I would like to understand difference between Zabbix LTS 5.0 vs Zabbix 5.0. Is it just that LTS has extended support? or does it mean when we install LTS version we have to option to buy support as well?
    Regards
    Sunil
  • Atsushi
    • Aug 2013
    • 2028
    There is no difference between them. Zabbix 5.0 is a version called LTS, which has a long support period. In context, it is sometimes referred to as "Zabbix 5.0 LTS" to emphasize that it is a version with a long support period.
    • dsunil79
      • Sep 2021
      thanks for the info.. any way we can see that in help or about section which states that we are on LTS or will it just show 5.0
