Regex HELP- extract data from snmp trap to TAG's
  • tfineberg
    • Sep 2021
    I am running Zabbix 5.4.4 and receiving a Zabbix trap and would like to add some info from the trap data to a tag on the trigger.
    The trigger fires off fine but the regex that looks for the string in the item data does not work. It keeps giving me back the complete item data in full in the tag
    Here is a link to the data and a working regex https://regex101.com/r/dCpLnq/1
    In the trigger tag I have put
    Name = XXXXX
    Value = {{ITEM.VALUE}.iregsub("35043.1.1.1201.5.1.2.0 type=4 value=STRING: (\n*.*)"gm, \1)}
    I have tried a bunch of different ways but none work
    {{ITEM.VALUE}.iregsub(35043.1.1.1201.5.1.2.0 type=4 value=STRING: (\n*.*) , \1)}
    {{ITEM.VALUE}.iregsub(35043.1.1.1201.5.1.2.0 type=4 value=STRING: (\n*.*) , \0)}
    {{ITEM.VALUE}.iregsub("35043.1.1.1201.5.1.2.0 type=4 value=STRING: (\n*.*)" , "\1")}
    {{ITEM.VALUE}.iregsub("35043.1.1.1201.5.1.2.0 type=4 value=STRING: (\n*.*)", \1)}
    {ITEM.VALUE}.iregsub(35043.1.1.1201.5.1.2.0 type=4 value=STRING: (\n*.*), \1)
    The issue is the Tag value gets set at (the full snmptrap string)
    DMS NAME: {13:48:47 2021/08/31 PDU INFO:
    requestid 863955185
    errorstatus 0
    errorindex 0
    messageid 0
    receivedfrom UDP: [172.16.1.2]:58447->[10.100.0.13]:162
    And not
    "SOLiD DMS-1200"
    Any help would be much appreciated
  • tflolo
    • Feb 2022
    Hey,
    I'm also struggeling with some snmp traps parsing, I have come past the tag part of it. I wanted to tag the equipment that generated the trap so i used this:
    {{ITEM.VALUE}.iregsub("SNMPv2-SMI::enterprises\.35642\.1\.2\.2\.1\.1\.2\s=\s(\".*\")", "\1")}
    To extract DAB PA 1 from:
    20220207.085428 UDP: [127.0.0.1]:47048->[172.16.238.2]:1162
    DISMAN-EVENT-MIB::sysUpTimeInstance = 315569
    SNMPv2-MIB::snmpTrapOID.0 = SNMPv2-SMI::enterprises.35642.1.2.0.2
    SNMPv2-MIB::sysName.0 = New system
    SNMPv2-SMI::enterprises.35642.1.2.2.1.1.6 = 146
    SNMPv2-SMI::enterprises.35642.1.2.2.1.1.5 = 3700
    SNMPv2-SMI::enterprises.35642.1.2.2.1.1.2 = "DAB PA 1"
    SNMPv2-SMI::enterprises.35642.1.2.2.1.1.4 = -200
    SNMPv2-SMI::enterprises.35642.1.2.0.0.1.0 = 10
    SNMPv2-SMI::enterprises.35642.1.2.2.1.1.3 = 1260
    SNMPv2-MIB::snmpTrapEnterprise.0 = SNMPv2-SMI::enterprises.35642
    The tag is on the trigger.
    When I watch the problems view my trigger is tagged with paName: "DAB PA 1"
    Hope it helps, I find zabbix quite hard to grasp, I'm not too familiar with it but maybe there are some tools that can help with writing expressions for triggers etc.
      Trying with your example, this is what worked for me to extract that "SOLiD DMS-1200" out of the trap into tag value... The final push seemed to be "\s+" there, until I kept 2 spaces, it was not working.
      {{ITEM.VALUE}.iregsub("35043\.1\.1\.1201\.5\.1\.2\ .0 type=4\s+value=STRING: "(.*?)"", "\1")}
      I was using 4.4... But as Long as I see, syntax for this is same in 5.4...
