With Zabbix 5.4, logsource() trigger function requires a parameter and a period; since documentation is not updated yet, and with previous version (https://www.zabbix.com/documentation...gers/functions) the syntax was logsource (<pattern>), I need some help with a custom trigger
The linked item is a working custom item that checks a log file, with the following key:
So the trigger expression should be:
Where "Failed" is the text to search in the log entry.
The triggers returns: "Cannot evaluate logsource(...): invalid regular expression", but I don't understand why the regexpr is not correct, it's just a text match and I tested it in zabbix (admin > general > regexp)
Tried also removing the #1 but nothing changed
Thanks in advance!
log[Path\to\file.log,"Some text '[A-Za-z0-9-]+' some other text: '[A-Za-z]+',"]
logsource(/Server Name/log[Path\to\file.log,"Some text '[A-Za-z0-9-]+' some other text: '[A-Za-z]+',"],#1,"Failed")=1
Thanks in advance!
