Interval Macros - Best Practices?
  • bradturnbough
    • Apr 2020
    • 22
    I started to look into the use of Macros for Item update interval's.
    Is is possible to MULTIPLY a macro so that I can use it in a trigger expression?
    For example:
    {$MACRO100} === 60s
    Item check interval == {$MACRO100}
    Trigger === max(item, {$MACRO100}*3)=0
    Is this possible?
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    No, this will not work.
