zabbix dashboards
  • knightwolf8877
    • Sep 2021
    • 20
    zabbix dashboards
    hi, I need help with dashboards and I am struggling to find the right info. so zabbix gets all this amazing information and I can see it all in latest data. we have 500 devices across 100 customers. lets take 1 windows computer I want to see a dashboard with 1)system information 2) every other graph. (maybe together) but I don't want to create this for every Windows host. 1) system information doesn't change much so needs to get a list (like windows system information) and the rest of the graphs just need to be listed in a nice long page. I would like to have a directory style list or way to see (customer) -> click (windows 1) get that view -> click back (windows 2) same view. I don't want to have to create this for every single host. - - - now I am using the windows zabbix active template and can see there is a bunch of linked templates listed but to change anything in each template -> then graph then -> click that dashboard and it's dashboard after dashboard after dashboard to get a full view of a host ... there is no parent template dashboard with all the sub metrics view. does that make sense
    MSP style of view.
  • knightwolf8877
    • Sep 2021
    • 20
    yes but all the metrics are showing in the parent template, they show in the child templates but then you need a dashboard for each one of those.
    can you tell me more about the dashboard with dynamic hosts how is this setup or are you just talking on the hosts then choosing dashboard or graphs?
      https://www.zabbix.com/documentation...n/host_screens
      You can make a dashboard in that parent template, so it will be applied to all of related hosts.
      And you can make ordinary dashboard with dynamic hosts, so you choose your hosts from dropdown and data is updated according your selection.
        Classic graph widget allows "dynamic item"... does not really affect other stuff...
        Maybe I was a bit too eager to suggest it.. Unfortunately I don't have latest version at hand to play around with options there...
        You can always submit dev request to change visualization options... If it receives enough interest, it might be developed..
