Reload Zabbix frontend every hour
  • stanton79
    • Jan 2020
    is there a php setting for reload every hour entire webpage of Zabbix frontend? Where is it?
    I know it’s not necessary, usually.
    My goal is to view the Zabbix dashboard in a TV browser,
    which however has the limit of activating the screen saver every hour.
    Maybe it won't work anyway, it is just a try.
  • Noobz
    • Jun 2020
    • 105
    Most TV's have settings to control the screen saver and power saving functions.
    • stanton79
      • Jan 2020
      Unfortunately not.
      There is no way to disable the screen saver while using the TV browser.
      We opened a support ticket with manufacturer but in vain .That's by design
      • Oz_Joris
        • Sep 2021
        • 19
        not sure that will help you but you have a refresh setting directly in the users administration settings.
        However, as stanton says the problem is not with refreshing the data.
        • stanton79
          • Jan 2020
          I confirm that this is not a real screensaver, in the case of this TV. In fact, the Zabbix dashboard changes constantly. It is a sleep after one hour of TV remote control inactivity, only when using the TV browser. Suspend does not occur if the Zabbix dashboard is displayed using a PC or Raspberry connected to the HDMI port. It's a shame. The browser on the TV works very well.
          In conclusion, the solution is to use an external device connected to the hdmi port or ... a vibrator placed under the TV remote control!
            • 4993
            I don't think it would help, if you reload a page. Your data is anyway refreshed time to time on dashboard... Your screensaver activates because TV itself has not been touched for an hour, ie no mouse movement or keyboard stroke etc......
