Disable disk space check on volume Shared memory?
  • bhlowe
    • Sep 2015
    How can I disable a disk free check for /dev/shm ?
    I get a lot of false alarms on my Synology NAS systems that are using the Panorama p9 SNMP agent.
    The trigger /alert message is:
    Free disk space is less than 20% on volume Shared memory
    Of course, I want to know if the main volume(s) get full.. but shared memory is handled by the operating system and the system is running well. I don't want to repartition my NAS system volumes...
    I have a hard time finding where triggers are defined and how to edit them from the web interface... so any details would be appreciated.
    Thank you,
    Brad
  • troffasky
    • Jul 2008
    • 639
    Edit the "Storage devices for SNMP discovery" regular expression to filter them out.
    • rajbps
      • Jun 2013
      Thank you,
      Brad
      @bhlowe
      Hi Bhlowe,
      Did you manage to get this sorted if yes what expression did you remove please?
      Rajbps
      • csacksico
        • Jan 2018
        Originally posted by rajbps
        @bhlowe
        Hi Bhlowe,
        Rajbps
        Bump!
        Having many frustrations trying to stop Zabbix from reporting this (and other unwanted notifications).
        • kaspars.mednis
          • Oct 2017
          • 349
          Administration -> General -> Regular Expressions (in the dropdown)
          edit Storage devices for SNMP discovery
          add your unwanted devices here, like
          ^(Physical memory|Virtual memory|Memory buffers|Cached memory|Swap space|Shared memory)$
          Regards,
          Kaspars
