Item not returning anything when using /usr/bin/timeout
  • mimizone
    • Sep 2015
    I wanted to use /usr/bin/timeout to kill an openvpn connection after 10s.
    My item is a UserParameter set up as follow:
    UserParameter=vpn[*],/usr/bin/timeout 10 /usr/sbin/openvpn $1.ovpn
    everything is great when the timeout is not triggered (basically that openvpn works). I can see the logs in the item on zabbix.
    but when the timeout is triggered, the item is never refreshed.
    I've tried shielding it with "bash -c" or change the signal of the timeout to 3 and 15 but it doesn't solve the problem.
    I also replaced timeout with the --tls-exit option of openvpn, but the same behavior is experienced in that case.
    Same issue if I let openvpn timeout itself after 5 retries.
    Any recommendation on how to go around this problem?
