problem connecting to postgres db
  • rpittom
    • Sep 2015
    I've installed zabbix from the RPMs on a Centos 6.6 server using the following -
    yum -y update
    rpm -ivh http://repo.zabbix.com/zabbix/2.4/rh...el6.noarch.rpm
    yum install zabbix-server-pgsql zabbix-web-pgsql zabbix-agent
    After that I made the config changes to my php.ini (validates in setup) and to my zabbix_server.conf to point to my external postgresql server which other applications connect to fine.
    The logging is set to debug and I see no issues but when I try to test my database connection with the same data in the zabbix_server.conf it just says "Error connecting to database."
     13356:20150926:143715.549 Starting Zabbix Server. Zabbix 2.4.6 (revision 54796).
     13356:20150926:143715.549 ****** Enabled features ******
     13356:20150926:143715.549 SNMP monitoring:           YES
     13356:20150926:143715.549 IPMI monitoring:           YES
     13356:20150926:143715.549 WEB monitoring:            YES
     13356:20150926:143715.549 VMware monitoring:         YES
     13356:20150926:143715.549 Jabber notifications:      YES
     13356:20150926:143715.549 Ez Texting notifications:  YES
     13356:20150926:143715.549 ODBC:                      YES
     13356:20150926:143715.549 SSH2 support:              YES
     13356:20150926:143715.549 IPv6 support:              YES
     13356:20150926:143715.549 ******************************
     13356:20150926:143715.549 using configuration file: /etc/zabbix/zabbix_server.conf
     13356:20150926:143715.549 In load_modules()
     13356:20150926:143715.549 End of load_modules():SUCCEED
     13356:20150926:143715.550 In init_database_cache()
     13356:20150926:143715.550 In zbx_mem_required_size() size:0 chunks_num:4 descr:'history cache' param:'HistoryCacheSize'
     13356:20150926:143715.550 End of zbx_mem_required_size() size:543
     13356:20150926:143715.550 In zbx_mem_create() descr:'history cache' param:'HistoryCacheSize' size:8388583
     13356:20150926:143715.550 valid user addresses: [0x7f3464485170, 0x7f3464c84fd8] total size: 8388200
     13356:20150926:143715.550 End of zbx_mem_create()
     13356:20150926:143715.550 In zbx_mem_required_size() size:0 chunks_num:1 descr:'history text cache' param:'HistoryTextCacheSize'
     13356:20150926:143715.550 End of zbx_mem_required_size() size:435
     13356:20150926:143715.550 In zbx_mem_create() descr:'history text cache' param:'HistoryTextCacheSize' size:16777216
     13356:20150926:143715.550 valid user addresses: [0x7f3463485178, 0x7f3464484ff0] total size: 16776824
     13356:20150926:143715.550 In init_trend_cache()
     13356:20150926:143715.550 In zbx_mem_required_size() size:0 chunks_num:1 descr:'trend cache' param:'TrendCacheSize'
     13356:20150926:143715.550 End of zbx_mem_required_size() size:422
     13356:20150926:143715.550 In zbx_mem_create() descr:'trend cache' param:'TrendCacheSize' size:4194304
     13356:20150926:143715.550 valid user addresses: [0x7f3463085170, 0x7f3463484ff0] total size: 4193920
     13356:20150926:143715.550 End of init_trend_cache()
     13356:20150926:143715.550 End of init_database_cache()
     13356:20150926:143715.550 In init_configuration_cache() size:8388608
     13356:20150926:143715.550 In zbx_mem_create() descr:'configuration cache' param:'CacheSize' size:7130317
     13356:20150926:143715.551 valid user addresses: [0x7f34629b8170, 0x7f3463084cc0] total size: 7129936
     13356:20150926:143715.551 End of zbx_mem_create()
     13356:20150926:143715.551 In zbx_strpool_create()
     13356:20150926:143715.551 In zbx_mem_create() descr:'string pool' param:'CacheSize' size:1258291
     13356:20150926:143715.551 valid user addresses: [0x7f3462884168, 0x7f34629b7328] total size: 1257920
     13356:20150926:143715.551 End of zbx_strpool_create()
     13356:20150926:143715.551 End of init_configuration_cache()
     13356:20150926:143715.551 In init_selfmon_collector()
     13356:20150926:143715.551 init_selfmon_collector() size:7072
     13356:20150926:143715.551 End of init_selfmon_collector() collector:0x7f3462882000
     13356:20150926:143715.551 In zbx_vc_init()
     13356:20150926:143715.551 In zbx_mem_required_size() size:0 chunks_num:1 descr:'value cache size' param:'ValueCacheSize'
     13356:20150926:143715.551 End of zbx_mem_required_size() size:427
     13356:20150926:143715.551 In zbx_mem_create() descr:'value cache size' param:'ValueCacheSize' size:8388608
     13356:20150926:143715.551 valid user addresses: [0x7f3462082170, 0x7f3462881ff0] total size: 8388224
     13356:20150926:143715.551 End of zbx_vc_init()
     13356:20150926:143715.551 In zbx_db_get_database_type()
     13356:20150926:143715.551 In DBconnect() flag:0
     13356:20150926:143715.570 query without transaction detected
     13356:20150926:143715.570 query [txnlev:0] [set schema 'public']
     13356:20150926:143715.571 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13356:20150926:143715.573 PostgreSQL Server version: 90404
     13356:20150926:143715.573 query without transaction detected
     13356:20150926:143715.573 query [txnlev:0] [set escape_string_warning to off]
     13356:20150926:143715.574 query [txnlev:0] [show standard_conforming_strings]
     13356:20150926:143715.574 query without transaction detected
     13356:20150926:143715.574 query [txnlev:0] [set bytea_output=escape]
     13356:20150926:143715.575 End of DBconnect():0
     13356:20150926:143715.575 query [txnlev:0] [select userid from users limit 1]
     13356:20150926:143715.576 there is at least 1 record in "users" table
     13356:20150926:143715.576 End of zbx_db_get_database_type():ZBX_DB_SERVER
     13356:20150926:143715.576 In DBcheck_version()
     13356:20150926:143715.576 In DBconnect() flag:0
     13356:20150926:143715.591 query without transaction detected
     13356:20150926:143715.591 query [txnlev:0] [set schema 'public']
     13356:20150926:143715.592 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13356:20150926:143715.594 PostgreSQL Server version: 90404
     13356:20150926:143715.594 query without transaction detected
     13356:20150926:143715.594 query [txnlev:0] [set escape_string_warning to off]
     13356:20150926:143715.595 query [txnlev:0] [show standard_conforming_strings]
     13356:20150926:143715.595 query without transaction detected
     13356:20150926:143715.596 query [txnlev:0] [set bytea_output=escape]
     13356:20150926:143715.596 End of DBconnect():0
     13356:20150926:143715.596 query [txnlev:0] [select 1 from information_schema.tables where table_name='dbversion' and table_schema='public']
     13356:20150926:143715.601 query [txnlev:0] [select mandatory,optional from dbversion]
     13356:20150926:143715.602 current database version (mandatory/optional): 02040000/02040000
     13356:20150926:143715.602 required mandatory version: 02040000
     13356:20150926:143715.602 End of DBcheck_version():SUCCEED
     13356:20150926:143715.602 In DBconnect() flag:0
     13356:20150926:143715.617 query without transaction detected
     13356:20150926:143715.617 query [txnlev:0] [set schema 'public']
     13356:20150926:143715.618 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13356:20150926:143715.620 PostgreSQL Server version: 90404
     13356:20150926:143715.620 query without transaction detected
     13356:20150926:143715.620 query [txnlev:0] [set escape_string_warning to off]
     13356:20150926:143715.621 query [txnlev:0] [show standard_conforming_strings]
     13356:20150926:143715.621 query without transaction detected
     13356:20150926:143715.621 query [txnlev:0] [set bytea_output=escape]
     13356:20150926:143715.622 End of DBconnect():0
     13356:20150926:143715.622 In DCload_config()
     13356:20150926:143715.622 query [txnlev:0] [select refresh_unsupported,discovery_groupid,snmptrap_logging,severity_name_0,severity_name_1,severity_name_2,severity_name_3,severity_name_4,severity_name_5,hk_events_mode,hk_events_trigger,hk_events_internal,hk_events_discovery,hk_events_autoreg,hk_services_mode,hk_services,hk_audit_mode,hk_audit,hk_sessions_mode,hk_sessions,hk_history_mode,hk_history_global,hk_history,hk_trends_mode,hk_trends_global,hk_trends from config]
     13356:20150926:143715.624 In DCsync_config()
     13356:20150926:143715.624 End of DCsync_config()
     13356:20150926:143715.624 End of DCload_config()
     13356:20150926:143715.624 In DCsync_configuration()
     13356:20150926:143715.624 query [txnlev:0] [select refresh_unsupported,discovery_groupid,snmptrap_logging,severity_name_0,severity_name_1,severity_name_2,severity_name_3,severity_name_4,severity_name_5,hk_events_mode,hk_events_trigger,hk_events_internal,hk_events_discovery,hk_events_autoreg,hk_services_mode,hk_services,hk_audit_mode,hk_audit,hk_sessions_mode,hk_sessions,hk_history_mode,hk_history_global,hk_history,hk_trends_mode,hk_trends_global,hk_trends from config]
     13356:20150926:143715.625 query [txnlev:0] [select hostid,proxy_hostid,host,ipmi_authtype,ipmi_privilege,ipmi_username,ipmi_password,maintenance_status,maintenance_type,maintenance_from,errors_from,available,disable_until,snmp_errors_from,snmp_available,snmp_disable_until,ipmi_errors_from,ipmi_available,ipmi_disable_until,jmx_errors_from,jmx_available,jmx_disable_until,status,name from hosts where status in (0,1,5,6) and flags<>2]
     13356:20150926:143715.627 query [txnlev:0] [select hostid,inventory_mode from host_inventory]
     13356:20150926:143715.629 query [txnlev:0] [select hostid,templateid from hosts_templates order by hostid,templateid]
     13356:20150926:143715.630 query [txnlev:0] [select globalmacroid,macro,value from globalmacro]
     13356:20150926:143715.631 query [txnlev:0] [select hostmacroid,hostid,macro,value from hostmacro]
     13356:20150926:143715.632 query [txnlev:0] [select interfaceid,hostid,type,main,useip,ip,dns,port,bulk from interface]
     13356:20150926:143715.633 query [txnlev:0] [select i.itemid,i.hostid,i.status,i.type,i.data_type,i.value_type,i.key_,i.snmp_community,i.snmp_oid,i.port,i.snmpv3_securityname,i.snmpv3_securitylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassphrase,i.ipmi_sensor,i.delay,i.delay_flex,i.trapper_hosts,i.logtimefmt,i.params,i.state,i.authtype,i.username,i.password,i.publickey,i.privatekey,i.flags,i.interfaceid,i.snmpv3_authprotocol,i.snmpv3_privprotocol,i.snmpv3_contextname,i.lastlogsize,i.mtime,i.delta,i.multiplier,i.formula,i.history,i.trends,i.inventory_link,i.valuemapid,i.units,i.error from items i,hosts h where i.hostid=h.hostid and h.status in (0,1) and i.flags<>2]
     13356:20150926:143715.638 query [txnlev:0] [select distinct t.triggerid,t.description,t.expression,t.error,t.priority,t.type,t.value,t.state,t.lastchange,t.status from hosts h,items i,functions f,triggers t where h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=t.triggerid and h.status in (0,1) and t.flags<>2]
     13356:20150926:143715.642 query [txnlev:0] [select d.triggerid_down,d.triggerid_up from trigger_depends d order by d.triggerid_down]
     13356:20150926:143715.643 query [txnlev:0] [select i.itemid,f.functionid,f.function,f.parameter,t.triggerid from hosts h,items i,functions f,triggers t where h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=t.triggerid and h.status in (0,1) and t.flags<>2]
     13356:20150926:143715.645 query [txnlev:0] [select r.name,e.expressionid,e.expression,e.expression_type,e.exp_delimiter,e.case_sensitive from regexps r,expressions e where r.regexpid=e.regexpid]
     13356:20150926:143715.646 In DCsync_config()
     13356:20150926:143715.646 End of DCsync_config()
     13356:20150926:143715.646 In DCsync_hosts()
     13356:20150926:143715.646 End of DCsync_hosts()
     13356:20150926:143715.646 In DCsync_host_inventory()
     13356:20150926:143715.646 End of DCsync_host_inventory()
     13356:20150926:143715.646 In DCsync_htmpls()
     13356:20150926:143715.646 End of DCsync_htmpls()
     13356:20150926:143715.646 In DCsync_gmacros()
     13356:20150926:143715.647 End of DCsync_gmacros()
     13356:20150926:143715.647 In DCsync_hmacros()
     13356:20150926:143715.647 End of DCsync_hmacros()
     13356:20150926:143715.647 In DCsync_interfaces()
     13356:20150926:143715.647 End of DCsync_interfaces()
     13356:20150926:143715.647 In DCsync_items()
     13356:20150926:143715.647 End of DCsync_items()
     13356:20150926:143715.647 In DCsync_triggers()
     13356:20150926:143715.647 End of DCsync_triggers()
     13356:20150926:143715.647 In DCsync_trigdeps()
     13356:20150926:143715.647 End of DCsync_trigdeps()
     13356:20150926:143715.648 In DCsync_functions()
     13356:20150926:143715.648 End of DCsync_functions()
     13356:20150926:143715.648 In DCsync_expressions()
     13356:20150926:143715.648 End of DCsync_expressions()
     13356:20150926:143715.648 DCsync_configuration() config     : sql:0.000774 sync:0.000097 sec.
     13356:20150926:143715.648 DCsync_configuration() hosts      : sql:0.002286 sync:0.000096 sec.
     13356:20150926:143715.648 DCsync_configuration() host_invent: sql:0.001550 sync:0.000073 sec.
     13356:20150926:143715.648 DCsync_configuration() templates  : sql:0.001351 sync:0.000101 sec.
     13356:20150926:143715.648 DCsync_configuration() globmacros : sql:0.000865 sync:0.000079 sec.
     13356:20150926:143715.648 DCsync_configuration() hostmacros : sql:0.000845 sync:0.000073 sec.
     13356:20150926:143715.648 DCsync_configuration() interfaces : sql:0.001077 sync:0.000086 sec.
     13356:20150926:143715.648 DCsync_configuration() items      : sql:0.005303 sync:0.000467 sec.
     13356:20150926:143715.648 DCsync_configuration() triggers   : sql:0.003892 sync:0.000188 sec.
     13356:20150926:143715.648 DCsync_configuration() trigdeps   : sql:0.000961 sync:0.000134 sec.
     13356:20150926:143715.648 DCsync_configuration() functions  : sql:0.001729 sync:0.000172 sec.
     13356:20150926:143715.648 DCsync_configuration() expressions: sql:0.001281 sync:0.000096 sec.
     13356:20150926:143715.648 DCsync_configuration() total sql  : 0.021915 sec.
     13356:20150926:143715.648 DCsync_configuration() total sync : 0.001661 sec.
     13356:20150926:143715.648 DCsync_configuration() proxies    : 0 (1009 slots)
     13356:20150926:143715.648 DCsync_configuration() hosts      : 1 (1009 slots)
     13356:20150926:143715.648 DCsync_configuration() hosts_h    : 1 (1009 slots)
     13356:20150926:143715.648 DCsync_configuration() ipmihosts  : 1 (1009 slots)
     13356:20150926:143715.648 DCsync_configuration() host_invent: 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() htmpls     : 14 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() gmacros    : 1 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() gmacros_m  : 1 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() hmacros    : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() hmacros_hm : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() interfaces : 1 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() interfac_ht: 1 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() if_snmpitms: 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() if_snmpaddr: 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() items      : 64 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() items_hk   : 64 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() numitems   : 58 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() snmpitems  : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() ipmiitems  : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() flexitems  : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() trapitems  : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() logitems   : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() dbitems    : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() sshitems   : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() telnetitems: 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() simpleitems: 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() jmxitems   : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() calcitems  : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() deltaitems : 0 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() functions  : 41 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() triggers   : 41 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() trigdeps   : 35 (1009 slots)
     13356:20150926:143715.649 DCsync_configuration() t_trigs[0] : 1 (32 allocated)
     13356:20150926:143715.649 DCsync_configuration() expressions: 4 (1009 slots)
     13356:20150926:143715.650 DCsync_configuration() queue[0]   : 0 (0 allocated)
     13356:20150926:143715.650 DCsync_configuration() queue[1]   : 0 (0 allocated)
     13356:20150926:143715.650 DCsync_configuration() queue[2]   : 0 (0 allocated)
     13356:20150926:143715.650 DCsync_configuration() queue[3]   : 0 (0 allocated)
     13356:20150926:143715.650 DCsync_configuration() queue[4]   : 0 (0 allocated)
     13356:20150926:143715.650 DCsync_configuration() pqueue     : 0 (0 allocated)
     13356:20150926:143715.650 DCsync_configuration() configfree : 94.900129%
     13356:20150926:143715.650 DCsync_configuration() strings    : 183 (1009 slots)
     13356:20150926:143715.650 DCsync_configuration() strpoolfree: 98.297771%
     13356:20150926:143715.650 === memory statistics for configuration cache ===
     13356:20150926:143715.650 free chunks of size >= 256 bytes:        1
     13356:20150926:143715.650 min chunk size:    6766680 bytes
     13356:20150926:143715.650 max chunk size:    6766680 bytes
     13356:20150926:143715.650 memory of total size 7129936 bytes fragmented into 468 chunks
     13356:20150926:143715.650 of those,    6766680 bytes are in        1 free chunks
     13356:20150926:143715.650 of those,     355784 bytes are in      467 used chunks
     13356:20150926:143715.650 ================================
     13356:20150926:143715.650 === memory statistics for string pool ===
     13356:20150926:143715.650 min chunk size:    1236872 bytes
     13356:20150926:143715.650 max chunk size:    1236872 bytes
     13356:20150926:143715.650 memory of total size 1257920 bytes fragmented into 186 chunks
     13356:20150926:143715.650 of those,    1236872 bytes are in        1 free chunks
     13356:20150926:143715.650 of those,      18088 bytes are in      185 used chunks
     13356:20150926:143715.650 End of DCsync_configuration()
     13356:20150926:143715.651 server #0 started [main process]
     13359:20150926:143715.654 server #3 started [poller #1]
     13360:20150926:143715.656 server #4 started [poller #2]
     13358:20150926:143715.658 server #2 started [db watchdog #1]
     13358:20150926:143715.658 db watchdog [pinging database]
     13358:20150926:143715.658 In DBconnect() flag:2
     13361:20150926:143715.659 server #5 started [poller #3]
     13362:20150926:143715.660 server #6 started [poller #4]
     13357:20150926:143715.661 server #1 started [configuration syncer #1]
     13357:20150926:143715.661 configuration syncer [waiting 60 sec for processes]
     13363:20150926:143715.662 server #7 started [poller #5]
     13364:20150926:143715.663 server #8 started [unreachable poller #1]
     13365:20150926:143715.665 server #9 started [trapper #1]
     13365:20150926:143715.665 trapper #1 [connecting to the database]
     13365:20150926:143715.665 In DBconnect() flag:0
     13366:20150926:143715.666 server #10 started [trapper #2]
     13366:20150926:143715.666 trapper #2 [connecting to the database]
     13366:20150926:143715.666 In DBconnect() flag:0
     13367:20150926:143715.675 server #11 started [trapper #3]
     13367:20150926:143715.675 trapper #3 [connecting to the database]
     13367:20150926:143715.675 In DBconnect() flag:0
     13368:20150926:143715.678 server #12 started [trapper #4]
     13368:20150926:143715.678 trapper #4 [connecting to the database]
     13368:20150926:143715.678 In DBconnect() flag:0
     13369:20150926:143715.678 server #13 started [trapper #5]
     13369:20150926:143715.678 trapper #5 [connecting to the database]
     13369:20150926:143715.678 In DBconnect() flag:0
     13370:20150926:143715.680 server #14 started [icmp pinger #1]
     13370:20150926:143715.680 icmp pinger #1 [getting values]
     13370:20150926:143715.680 In get_pinger_hosts()
     13370:20150926:143715.680 In DCconfig_get_poller_items() poller_type:3
     13370:20150926:143715.680 End of DCconfig_get_poller_items():0
     13370:20150926:143715.681 End of get_pinger_hosts():0
     13370:20150926:143715.681 In process_pinger_hosts()
     13370:20150926:143715.681 End of process_pinger_hosts()
     13370:20150926:143715.681 In DCconfig_get_poller_nextcheck() poller_type:3
     13370:20150926:143715.681 End of DCconfig_get_poller_nextcheck():-1
     13370:20150926:143715.681 icmp pinger #1 [got 0 values in 0.000182 sec, idle 5 sec]
     13371:20150926:143715.681 server #15 started [alerter #1]
     13371:20150926:143715.681 alerter [connecting to the database]
     13371:20150926:143715.681 In DBconnect() flag:0
     13372:20150926:143715.681 server #16 started [housekeeper #1]
     13372:20150926:143715.682 housekeeper [startup idle for 30 minutes]
     13373:20150926:143715.686 server #17 started [timer #1]
     13373:20150926:143715.686 timer #1 [connecting to the database]
     13373:20150926:143715.686 In DBconnect() flag:0
     13374:20150926:143715.688 server #18 started [http poller #1]
     13374:20150926:143715.688 http poller #1 [connecting to the database]
     13374:20150926:143715.688 In DBconnect() flag:0
     13376:20150926:143715.690 server #20 started [history syncer #1]
     13376:20150926:143715.690 history syncer #1 [connecting to the database]
     13376:20150926:143715.690 In DBconnect() flag:0
     13377:20150926:143715.691 server #21 started [history syncer #2]
     13377:20150926:143715.691 history syncer #2 [connecting to the database]
     13377:20150926:143715.691 In DBconnect() flag:0
     13378:20150926:143715.692 server #22 started [history syncer #3]
     13378:20150926:143715.692 history syncer #3 [connecting to the database]
     13378:20150926:143715.692 In DBconnect() flag:0
     13358:20150926:143715.697 query without transaction detected
     13358:20150926:143715.697 query [txnlev:0] [set schema 'public']
     13380:20150926:143715.698 server #24 started [escalator #1]
     13380:20150926:143715.698 escalator [connecting to the database]
     13380:20150926:143715.698 In DBconnect() flag:0
     13381:20150926:143715.699 server #25 started [proxy poller #1]
     13381:20150926:143715.699 proxy poller #1 [connecting to the database]
     13381:20150926:143715.699 In DBconnect() flag:0
     13379:20150926:143715.699 server #23 started [history syncer #4]
     13379:20150926:143715.699 history syncer #4 [connecting to the database]
     13379:20150926:143715.699 In DBconnect() flag:0
     13358:20150926:143715.706 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13382:20150926:143715.712 server #26 started [self-monitoring #1]
     13382:20150926:143715.712 self-monitoring [processing data]
     13382:20150926:143715.712 In collect_selfmon_stats()
     13382:20150926:143715.712 End of collect_selfmon_stats()
     13382:20150926:143715.712 self-monitoring [processed data in 0.000071 sec, idle 1 sec]
     13358:20150926:143715.723 PostgreSQL Server version: 90404
     13358:20150926:143715.723 query without transaction detected
     13358:20150926:143715.723 query [txnlev:0] [set escape_string_warning to off]
     13358:20150926:143715.737 query [txnlev:0] [show standard_conforming_strings]
     13358:20150926:143715.739 query without transaction detected
     13358:20150926:143715.739 query [txnlev:0] [set bytea_output=escape]
     13358:20150926:143715.741 End of DBconnect():0
     13358:20150926:143715.741 db watchdog [syncing configuration]
     13358:20150926:143715.741 In sync_config()
     13358:20150926:143715.741 query [txnlev:0] [select mt.mediatypeid,mt.type,mt.description,mt.smtp_server,mt.smtp_helo,mt.smtp_email,mt.exec_path,mt.gsm_modem,mt.username,mt.passwd,m.sendto from media m,users_groups u,config c,media_type mt where m.userid=u.userid and u.usrgrpid=c.alert_usrgrpid and m.mediatypeid=mt.mediatypeid and m.active=0 and mt.status=0]
     13365:20150926:143715.775 query without transaction detected
     13365:20150926:143715.775 query [txnlev:0] [set schema 'public']
     13365:20150926:143715.783 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13365:20150926:143715.786 PostgreSQL Server version: 90404
     13365:20150926:143715.786 query without transaction detected
     13365:20150926:143715.786 query [txnlev:0] [set escape_string_warning to off]
     13366:20150926:143715.792 query without transaction detected
     13366:20150926:143715.792 query [txnlev:0] [set schema 'public']
     13366:20150926:143715.798 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13358:20150926:143715.800 End of sync_config() values_num:0
     13358:20150926:143715.800 db watchdog [synced alerts config in 0.141826 sec, idle 60 sec]
     13366:20150926:143715.803 PostgreSQL Server version: 90404
     13366:20150926:143715.803 query without transaction detected
     13366:20150926:143715.803 query [txnlev:0] [set escape_string_warning to off]
     13365:20150926:143715.814 query [txnlev:0] [show standard_conforming_strings]
     13365:20150926:143715.815 query without transaction detected
     13365:20150926:143715.815 query [txnlev:0] [set bytea_output=escape]
     13365:20150926:143715.816 End of DBconnect():0
     13365:20150926:143715.816 trapper #1 [processed data in 0.000000 sec, waiting for connection]
     13368:20150926:143715.818 query without transaction detected
     13368:20150926:143715.818 query [txnlev:0] [set schema 'public']
     13369:20150926:143715.819 query without transaction detected
     13369:20150926:143715.819 query [txnlev:0] [set schema 'public']
     13367:20150926:143715.819 query without transaction detected
     13367:20150926:143715.819 query [txnlev:0] [set schema 'public']
     13366:20150926:143715.819 query [txnlev:0] [show standard_conforming_strings]
     13368:20150926:143715.820 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13367:20150926:143715.820 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13366:20150926:143715.821 query without transaction detected
     13366:20150926:143715.821 query [txnlev:0] [set bytea_output=escape]
     13369:20150926:143715.821 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13367:20150926:143715.825 PostgreSQL Server version: 90404
     13367:20150926:143715.825 query without transaction detected
     13367:20150926:143715.825 query [txnlev:0] [set escape_string_warning to off]
     13366:20150926:143715.825 End of DBconnect():0
     13366:20150926:143715.825 trapper #2 [processed data in 0.000000 sec, waiting for connection]
     13371:20150926:143715.826 query without transaction detected
     13371:20150926:143715.826 query [txnlev:0] [set schema 'public']
     13373:20150926:143715.827 query without transaction detected
     13373:20150926:143715.827 query [txnlev:0] [set schema 'public']
     13368:20150926:143715.829 PostgreSQL Server version: 90404
     13368:20150926:143715.829 query without transaction detected
     13368:20150926:143715.829 query [txnlev:0] [set escape_string_warning to off]
     13376:20150926:143715.831 query without transaction detected
     13376:20150926:143715.831 query [txnlev:0] [set schema 'public']
     13369:20150926:143715.835 PostgreSQL Server version: 90404
     13369:20150926:143715.835 query without transaction detected
     13369:20150926:143715.835 query [txnlev:0] [set escape_string_warning to off]
     13378:20150926:143715.837 query without transaction detected
     13378:20150926:143715.837 query [txnlev:0] [set schema 'public']
     13371:20150926:143715.838 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13373:20150926:143715.838 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13376:20150926:143715.838 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13374:20150926:143715.838 query without transaction detected
     13374:20150926:143715.838 query [txnlev:0] [set schema 'public']
     13378:20150926:143715.839 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13377:20150926:143715.842 query without transaction detected
     13377:20150926:143715.842 query [txnlev:0] [set schema 'public']
     13374:20150926:143715.842 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13376:20150926:143715.845 PostgreSQL Server version: 90404
     13376:20150926:143715.845 query without transaction detected
     13376:20150926:143715.845 query [txnlev:0] [set escape_string_warning to off]
     13377:20150926:143715.845 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13374:20150926:143715.848 PostgreSQL Server version: 90404
     13374:20150926:143715.848 query without transaction detected
     13374:20150926:143715.848 query [txnlev:0] [set escape_string_warning to off]
     13377:20150926:143715.849 PostgreSQL Server version: 90404
     13377:20150926:143715.849 query without transaction detected
     13377:20150926:143715.849 query [txnlev:0] [set escape_string_warning to off]
     13367:20150926:143715.850 query [txnlev:0] [show standard_conforming_strings]
     13368:20150926:143715.851 query [txnlev:0] [show standard_conforming_strings]
     13369:20150926:143715.851 query [txnlev:0] [show standard_conforming_strings]
     13379:20150926:143715.853 query without transaction detected
     13379:20150926:143715.853 query [txnlev:0] [set schema 'public']
     13367:20150926:143715.853 query without transaction detected
     13367:20150926:143715.853 query [txnlev:0] [set bytea_output=escape]
     13368:20150926:143715.853 query without transaction detected
     13368:20150926:143715.853 query [txnlev:0] [set bytea_output=escape]
     13369:20150926:143715.853 query without transaction detected
     13369:20150926:143715.853 query [txnlev:0] [set bytea_output=escape]
     13373:20150926:143715.854 PostgreSQL Server version: 90404
     13373:20150926:143715.854 query without transaction detected
     13373:20150926:143715.854 query [txnlev:0] [set escape_string_warning to off]
     13380:20150926:143715.854 query without transaction detected
     13380:20150926:143715.854 query [txnlev:0] [set schema 'public']
     13371:20150926:143715.854 PostgreSQL Server version: 90404
     13371:20150926:143715.854 query without transaction detected
     13371:20150926:143715.854 query [txnlev:0] [set escape_string_warning to off]
     13367:20150926:143715.855 End of DBconnect():0
     13367:20150926:143715.855 trapper #3 [processed data in 0.000000 sec, waiting for connection]
     13368:20150926:143715.855 End of DBconnect():0
     13368:20150926:143715.855 trapper #4 [processed data in 0.000000 sec, waiting for connection]
     13369:20150926:143715.855 End of DBconnect():0
     13369:20150926:143715.855 trapper #5 [processed data in 0.000000 sec, waiting for connection]
     13378:20150926:143715.855 PostgreSQL Server version: 90404
     13378:20150926:143715.855 query without transaction detected
     13378:20150926:143715.855 query [txnlev:0] [set escape_string_warning to off]
     13379:20150926:143715.856 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13381:20150926:143715.856 query without transaction detected
     13381:20150926:143715.856 query [txnlev:0] [set schema 'public']
     13376:20150926:143715.856 query [txnlev:0] [show standard_conforming_strings]
     13374:20150926:143715.856 query [txnlev:0] [show standard_conforming_strings]
     13377:20150926:143715.856 query [txnlev:0] [show standard_conforming_strings]
     13371:20150926:143715.856 query [txnlev:0] [show standard_conforming_strings]
     13373:20150926:143715.857 query [txnlev:0] [show standard_conforming_strings]
     13380:20150926:143715.857 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13378:20150926:143715.857 query [txnlev:0] [show standard_conforming_strings]
     13380:20150926:143715.860 PostgreSQL Server version: 90404
     13380:20150926:143715.860 query without transaction detected
     13380:20150926:143715.860 query [txnlev:0] [set escape_string_warning to off]
     13371:20150926:143715.860 query without transaction detected
     13371:20150926:143715.860 query [txnlev:0] [set bytea_output=escape]
     13373:20150926:143715.860 query without transaction detected
     13373:20150926:143715.860 query [txnlev:0] [set bytea_output=escape]
     13381:20150926:143715.860 query [txnlev:0] [select oid from pg_type where typname='bytea']
     13376:20150926:143715.861 query without transaction detected
     13376:20150926:143715.861 query [txnlev:0] [set bytea_output=escape]
     13374:20150926:143715.861 query without transaction detected
     13374:20150926:143715.861 query [txnlev:0] [set bytea_output=escape]
     13377:20150926:143715.861 query without transaction detected
     13377:20150926:143715.861 query [txnlev:0] [set bytea_output=escape]
     13378:20150926:143715.861 query without transaction detected
     13378:20150926:143715.861 query [txnlev:0] [set bytea_output=escape]
     13379:20150926:143715.861 PostgreSQL Server version: 90404
     13379:20150926:143715.861 query without transaction detected
     13379:20150926:143715.861 query [txnlev:0] [set escape_string_warning to off]
     13371:20150926:143715.862 End of DBconnect():0
  • rpittom
    • Sep 2015
    This is now corrected and I believe the issue was with selinux. disabling verified.
